Hi everyone,
Any tips on removal of a stubborn stat housing?
Nuts undone easy but housing doesnt wish to move :-(
1975 stat housing
- Paul Scott
- Surname: Scott
1975 stat housing
Re: 1975 stat housing
Dribble Coca Cola down the studs and leave overnight. When I had to remove the one on my 77 car I bought a spare first and then used a round piece of wood through the hose aperture and gently wiggled it about. It eventually came off undamaged. When replacing smear copper grease on the studs which stops the electrolytic reaction between the steel and aluminium.
- Paul Scott
- Surname: Scott
Thanks for the reply Vic
I will give that a go in the morning. I added some pblaster earlier. So I will add some Coke tomorrow & get a new housing on order.
Hi Paul,
Like Vic,i purchase a new stat housing before removing the old one. Having done it probably 4 times now on my 1980 Roadster i also use a lever through the watef elbow, in conjunction with using a chisel with a few taps oa a heavy mallet working round the three sides between the housing /gasket/ block until it starts to lift off.
Good luck.
Good luck.
- Paul Scott
- Surname: Scott
Thanks Charles.
New housing ordered, arriving tomorrow. So hopefuly I can tease the old one off tomorrow night.
