King pin shims.
Posted: Tue Mar 26, 2024 7:25 am
by Rommel
So I have some vertical movement in my stub axles, so going to add some shims under the top trunnion should I also replace the bronze thrust washer? is this subject to much wear? or just add more shims? In the past with king pin issues I have just replaced the whole assembly with recon units but everything else is in good order just a bit of lift in stub axle, also can anyone tell me the thickness of a new bronze thrust washer? not taken it apart yey all soaking in WD40 at the moment.
Thanks in advance.
Re: King pin shims.
Posted: Tue Mar 26, 2024 8:53 am
It's a long time since I did this job ( due to relatively low mileage in recent years) and I was not spending a lot of money on the BGT.
However, my view is that the thrust washer is exactly that - just there to act as a bearing surface. I still have a string of shims of different sizes to take up the slack to the correct specification. They are steel. So as long as the bronze thrust washer still looks reasonable, all you should need is a set of steel shims/washers of the correct size.
Re: King pin shims.
Posted: Thu Apr 04, 2024 7:54 pm
by Rommel
Ok so just done this and found that both the thrust washer and shims are subject to wear, new thrust washer significantly thicker than the old one.
So new washer and two new shims (57 thou) gave correct clearance of 0.02 thou.
Re: King pin shims.
Posted: Thu Apr 04, 2024 8:25 pm
Good job!
Re: King pin shims.
Posted: Mon Apr 15, 2024 2:26 pm
by Randy Forbes
Maybe not such a necessity on an MGB, but the Healey (100, 100/6 & 3000) use an identical king-pin/stub-axle arrangement (of slightly increased size) and suppliers offer a "Nadella type" needle-roller bearing substitute for the bronze thrust washer.
Clearances are set as you would for the bronze thrust washer.
While it's nothing like adding real
power steering, there was a noticeable reduction in steering effort.
