Seat adjustment
Posted: Sat Aug 12, 2023 1:13 pm
by A D Price
I am finding my MGBGT short of headroom. Not sure if the webasto sunroof takes any headroom but could do with an extra inch. Does anybody make lowered runners for the seats or has anybody got any tips. My car is 1974.
Re: Seat adjustment
Posted: Sun Aug 13, 2023 7:12 pm
by Tom Brearley
Sounds like a pain in the neck!
You could maybe experiment with loosening the webbing which the seat foam sits on?
Re: Seat adjustment
Posted: Tue Aug 15, 2023 2:02 pm
by Allan T
You've checked you have the standard slender wooden supports under your runners? The shorter-than-average p/o had fitted 2" x 2" in mine. Worth a look, if you haven't already. Good luck!
Re: Seat adjustment
Posted: Tue Aug 15, 2023 8:25 pm
by Bumpa
I'm only 5' 8" with short legs and a longer back and I have enough headroom in the GT. But when I took it on a local circuit and had to wear a helmet, I was forced to bend my neck to get under the roof. So I understand where you are coming from. How tall are you, and is your height in your back or legs? A very tall friend gets away by reclining the seat more.
Re: Seat adjustment
Posted: Thu Aug 17, 2023 3:24 pm
by A D Price
Thanks for your replies took the wood out under the runners which has helped. As for putting the seat back in -thats fiddly
Alun
Re: Seat adjustment
Posted: Fri Aug 18, 2023 10:03 am
by Bumpa
A tip for refitting the seat. Get hold of four extra bolts of a reasonable length. Cut their heads off. Screw them into the seat fixing holes. Place seat over the headless bolts, then remove them one by one putting the correct bolts in their place. Makes it much easier.
Re: Seat adjustment
Posted: Sat Sep 16, 2023 4:21 pm
by Allan T
Separate backs and squabs when refitting seats.
It adds a stage to the job, but makes it so very much easier and - counterintuitively - quicker.
Good luck!
