Rollover rear cage for MG BGT
Posted: Fri Jul 28, 2023 1:25 pm
I am looking at fitting a rear rollover cage with a diagonal but no harness bar to our MG BGT. I intend to leave the harnesses attached where they are, at the base of the seat back as I want to be able to fold/unfold the rear seat as required. I am not required to have a rollover cage but would be more comfortable if one were fitted for the events we are doing.
Couple of questions:
I suspect the seat back will foul the lower part of the diagonal? If this is the case how much would I need to reshape/trim the seatback to allow it fold/unfold?
We also use the inertias for transits and getting to events - can I mount the reels once the roll bar is fitted?
