Cellulose paint suppliers
- Steven collins
- Forename: Steve
- Surname: Collins
HAPPY NEW YEAR to one and all.
Does any one know of a company in North Essex/Suffolk that can test for colour match then mix and supply Cellulose paint?
I want to respray a few panels on the MG, May even end up as a full respray!! however, the paint is not a standard Red. Local garage tested the paint but could only get a 97% match.
Many thanks in advance.
Steve.
Steve.
Re: Cellulose paint suppliers
Hi Steve, I can't answer your question directly as I am just North of Edinburgh, but what I can say is that getting a good colour match is extremely tricky. Especially so for red colours as reds tend to fade and change colour. Additionally, reds are translucent and the finished colour depends very much on the colour of the primer/basecoat underneath.
There are a number of companies I have used for cellulose, I can give you some contact details if you wish, but you probably have them already.
- Steven collins
- Forename: Steve
- Surname: Collins
Thanks Ian,
Yes fully aware of how difficult Red is to match especially when you put it under sodium light!! That’s why I may have to end up respraying the whole car. Incidentally the colour is bright red with an unspecified amount of orange mixed in!!
You never know the paint suppliers up where you are just might be better than down here…
Hi Steven.
Your local auto paint supplier should be able to identify a close match if you take a panel along (I took my midget boot lid to get a match). Technology these days can work wonders.
But then your problem will be that they probably will not be able to supply cellulose. If you can get a name and code of a colour match, you could approach the cellulose suppliers and see if they can produce that formulation. Buy a half litre initially and see how well it matches.
I have had good service from HMG paints in Manchester. They do mail order and having tried most of the other suppliers, I would recommend them.
- Steven collins
- Forename: Steve
- Surname: Collins
If I cannot find a more local supplier then I will give them a call.
Will let you know how I get on…
For a full respray and say minimum of 4/5 coats would 5ltrs be enough for a roadster?
Morelli in Wickford are car paint stockists. Ive only ever heard good things said about them.
Any reason why you are going for old school cellulose rather than acrylic ?
Hi Chris,
I'm interested to hear about acrylic paint for the B? I've generally used cellulose because it's relatively (!) non-toxic - no isocyanates, and it's easy to apply and to rectify if any problems/stone chips etc.
Does acrylic need a two-pack lacquer to finish?
P.s. in the MGB workshop manual cellulose paint is specified for refinishing. Ault and Wiborg, long since deceased.
- Steven collins
- Forename: Steve
- Surname: Collins
Chris,
The reason for using Cellulose is exactly as Ian has said -
It's relatively non-toxic, it's easy to apply. As I’m not a “professional” paint sprayer less to go wrong - plus the car is already coated in cellulose so would like to keep it the same.
Unless there is a kind hearted person out there who wants to volunteer their paint spraying expertise and time
You could try these people
http://carspaints.com/
They have branches dotted around Essex and in Ipswich. My vermillion GT is looking resplendent in its new paint job using paint from their latchingdon branch. Mine was professionally painted so I don’t know for certain he used cellulose but I think he did. Mine is also a factory colour but the match was perfect. They should be able to find your colour for you.
