My horn doesn't work, when I took the horn button off the steering wheel it seems that the horn bullet terminal isn't there.
How would I go about fitting a new one. Pictures, drawings or diagrams would be helpful.
Inexistent horn bullet terminal
- Remyd
- Forename: Remy
- Surname: Dubois
Remy Dubois
1971 MGB GT
1971 MGB GT
Re: Inexistent horn bullet terminal
Which wheel is on the car Remy?
Can you post a picture of what you have?
Is that your car on the homepage?
As with many questions, I always like to have a look at Paul Hunt's comprehensive MGB site mgb-stuff.org.uk If you go to the home page there click on Spanners to enter the technical sections, which are large and really helpful. For the horn push fitted to various models of MGB go to http://mgb-stuff.org.uk/electricstext1.htm#hornpush
Hi Remy
As Paul mentioned it depends on the wheel fitted. Attached are a couple of pictures that might help. I suspect you are missing the brush contact. This is readily available from the specialist suppliers Part No BHA5041. Alternatively have a look on the internet for an original item. (More chance it will fit and work.)
Hope this helps.
Hope this helps.
- Remyd
- Forename: Remy
- Surname: Dubois
Thanks, I actually have got this saved on my iPhone and looked at it yesterday.Bumpa wrote: ↑Tue Mar 30, 2021 1:33 pm As with many questions, I always like to have a look at Paul Hunt's comprehensive MGB site mgb-stuff.org.uk If you go to the home page there click on Spanners to enter the technical sections, which are large and really helpful. For the horn push fitted to various models of MGB go to http://mgb-stuff.org.uk/electricstext1.htm#hornpush
Remy Dubois
1971 MGB GT
1971 MGB GT
- Remyd
- Forename: Remy
- Surname: Dubois
Hi Mike, I think you're right. The brush contact should fit in the middle in mine I think. As always I forgot to take a picture but will try to remember tomorrow.Michael Barclay wrote: ↑Tue Mar 30, 2021 6:39 pm Hi Remy
Hope this helps.
Remy Dubois
1971 MGB GT
1971 MGB GT
- Remyd
- Forename: Remy
- Surname: Dubois
Yes, forgot I had pictures of the interior on here. I took the centre piece out yesterday, looks like the bullet connector goes in the middle. My question is, how do you fit it?Paul Scott wrote: ↑Wed Mar 31, 2021 5:51 am 20210103160630-c45550ca-cu_e520x360.jpg
Looks like a Motolita
Do you just slot it in or do I have to take the wheel off and screw it in somehow.
Remy Dubois
1971 MGB GT
1971 MGB GT
- Remyd
- Forename: Remy
- Surname: Dubois
That looks very similar to the one on my 1971 GT, I'll have a closer look and take pictures this afternoon after work.Paul Scott wrote: ↑Wed Mar 31, 2021 7:23 am hp5[1].jpg
My wheel has the same set up as this 1975B
Remy Dubois
1971 MGB GT
1971 MGB GT
