Inexistent horn bullet terminal
Re: Inexistent horn bullet terminal
Hi Remy,
I thought by 1970 the horn was operated by pushing the end of the indicator stalk. This seems to be confirmed by Clausager that from September 1969 a new column stalk was introduced that operated the indicators, headlight main beam and flash and the horn. The change was from car number 187170 for roadsters or 187841 for GTs. The new stalk has a square end with a chrome button. It is shorter than the previous one and looks like the one in your picture. Pretty much the whole of the BMC range were fitted by a version of this switch at the same time.
Are you looking in the right place to operate the horn?
Hi Peter. For interest: my 72 BGT (which I have owned since 1978) has a horn push in the centre of the steering wheel and a contact "pencil" as illustrated in this thread. Can be a bit troublesome if the semi-collapsible steering column moves in and out like mine used to!
...and my 1969 Roadster has the earlier steering column and the horn button on the stalk! This might show that the stalk can be easily swapped for a later one.
I have looked up the parts in the Moss catalogue and they give the change point for the stalk as Clausager
Thanks Peter. I've always been pretty certain my BGT was as it left the factory (1972) when I got it in 1978. It really had just been driven and serviced. Certainly the sills needed replacement in 1978 as I discovered after I bought it and tried jacking it up!
Peter,
see Clausager - top of page 146 - "1971 model year Changes to all cars. horn push returned to steering wheel centre"
- Remyd
- Forename: Remy
- Surname: Dubois
Here's a picture of the inside of the horn button in the centre of the horn.
Remy Dubois
1971 MGB GT
1971 MGB GT
OK Remy. That is an aftermarket wheel and is the same as is shown on Paul Hunt's web page. I have taken the liberty of copying his useful picture.
The other problem that sometimes happens is that the column needs to be earthed. This can be easily checked with a multimeter.
The wire that you see going through the hole should be soldered to the ring behind the wheel. If you take off the shrouds round the column you will see a view similar to Paul's picture. Rubbing on the ring should be a brass contact which is connected to the wire from the horns. When you push the horn button you earth the supply and the horns sound.The other problem that sometimes happens is that the column needs to be earthed. This can be easily checked with a multimeter.
- Remyd
- Forename: Remy
- Surname: Dubois
Thanks, I'll have a more in depth look when I have a little time between work.Bumpa wrote: ↑Wed Mar 31, 2021 7:14 pm OK Remy. That is an aftermarket wheel and is the same as is shown on Paul Hunt's web page. I have taken the liberty of copying his useful picture.
Remy Dubois
1971 MGB GT
1971 MGB GT
Hi Ian,Ian Fozzard wrote: ↑Wed Mar 31, 2021 1:13 pm Peter,
Thanks for pointing that out. I assumed that the Sept 1969 (1970 model year) was the point of the change and I didn't read any further on.
Easily missed Peter! The steering column/horn combinations do not seem to be particularly well documented, and who would have expected MG to have reverted back to a previous configuration so quickly?
Have a good Easter!
Have a good Easter!
