FED UP WITH PUMPING WATER ONTO YOUR SCREEN?
You are nearly an originality freak?
You do this…
Carefully prise open the pump body and insert a plunger type electric switch so the original plunger operates the switch. Wire the unit to a windscreen washer pump and hey presto you have an electric pump system which still looks original from the cockpit.
