What year is My MGB
bandini
Forename: Howard
Surname: Ritter
What year is My MGB
Post by bandini »
I am new to the register and thank you for letting me join. I am interested in what year my MGB is. The chassis number is GHN 3L/ 688 and my engine
number is 1 8G-U-H 1117 can some body decipher this. Thanks Tim
Re: What year is My MGB
Hi Tim,
I believe you have an early MGB Roadster - i.e. 1962
Per Barrie's Notes on the MGB:-
G= MG
H= Overhead valve engine
N= Sports (2 seater)
3= 3rd series (the 1st & 2nd were the MGA
L= Left hand drive (RHD cars have no letter)
Per Clausager:-
The engine numbers with that reference started with 101 in May 62 , but were higher than yours by December 62.
I've had a look in Clausager's book "Original MGB" and come up with this. Certainly your car appears to be an early one.
G means it is an MG
H means it has an engine between 1400 and 2000 cc
N means it is a two seat tourer
3 means it is a mark 1 model built between 1962 -1967. These are known as the pull-handle cars due to the outer door handles.
L means it is left hand drive
The next numbers indicate its build number. These started in May 1962 with 101. By January 1963 they were up to 4619. If your car really is 688 it is a 1962 - there are very few of these left. Look very carefully at the chassis plate as it is easy to misread the numbers
The engine number also points to a 1962 build date. By December 1962 they were up to 18G-U-H/4385.
bandini
Forename: Howard
Surname: Ritter
Post by bandini »
Thanks for the info I love to drive this car. Cheers Tim
Andrew Vigor
Forename: Andrew
Surname: Vigor
Post by Andrew Vigor »
Hi Tim, this car is already a member of our Register. Could you register your ownership with us and we will reply with the information that we have. It is free to register go to www.mgb-register.org/register/ and scroll down.
Regards, Andrew
MGB Registrar
bandini
Forename: Howard
Surname: Ritter
Post by bandini »
I went to the Register and replied to your request Thanks Tim
