Cracked Head
Hazza1190
Forename: Harry
Surname: Bukin
Cracked Head
Post by Hazza1190 »
Hi Guys,
Hope everyone's doing well.
Unfortunately upon cleaning the head up this weekend to send off the Peter Burgess (for the ecotune work), I have noticed a crack between cyl 1 and 2 (see pics below). I emailed some pics to Peter himself and he thinks the head is toast. This wouldn't worry that much usually but its a 12H2708 large valve head which seem more expensive and rare, so i was happy that I had one in the first place. Is it worth my time and money trying to source another large valve head? Or is the performance gains negligible, even after Peter has worked his magic?
Thanks!
Harry.
Re: Cracked Head
I would say that whatever Peter advises is the advice to be accepted!!
I think there may be folk out there who could weld the head, but again I would defer to Peter.
B series heads are still reasonably easy to come by, so your best bet is probably to get another and let Peter do his work on it. I would have thought that Peter could bring most head castings up to a similar level of efficiency. He may even be able to supply a suitable one for you?
The reason that some heads may be more expensive is perhaps due to competition regs which limit what work can be done, therefore a good "standard" head may be worth seeking out.
Peter could perhaps confirm whether this is the case?
Re: Cracked Head
Hi Harry,
Although you could get the head repaired, the process is time consuming and quite costly and you would still need to persuade Peter Burgess to work on it. If you source another second hand one, there is no guarantee that it will not be cracked as well. Best bet I think is to ask Peter Burgess if he can supply a head, and work on that or sell you a modified head off the shelf. In his book he tells readers not to worry if they don't have one of the better castings like the 12H2709 as they can all be modified to the same spec.
The 12H2709 heads are rare because they were only fitted to MGBs for 2 years and the Austin 1800S for the same period. The people racing in the standard spec classes like to use them, as the class regulation specify the head can't be polished, only grit blasted to clean them and as the have the best gas flow they are quite sought after.
ChargedAutoGT
Forename: Graham
Surname: Moore
Re: Cracked Head
Post by ChargedAutoGT »
It's toast.
There is another consideration. did this come off your car? And if not does your car have an 18V engine as the 2709 head requires cutouts for the exhaust valves which are only present on 18V?
A 12H1326 or 4736 can be retro-fitted with larger valves. I have had my 1326 done by Peter But it's not on the car yet so cannot report on differences.
Lastly - I read from someone who went out and bought a new head from County - then sent it to Peter for Econotune job . He said Peter had to return it saying it was NOT suitable for Econotune modification and most other mods. Now this is what I rear - but if that is a thought in your mins I would double check with him first.
I also bought a 2709 ... same issue. then another - different crack. But then I found a good one which is one my car now. a numbers game.....
The larger valves will have a positive effect in the higher RPM ranges, difficult to say exactly where - or if the seat-o-the-pants-meter can tell. but it's nice to have the correct head.
Re: Cracked Head
I haven't had any direct experience of County cylinder heads, but understand (from a reliable source) that they are very poor castings. A lot of irregularities in the ports, casting flashings etc.
I would agree with Peter (Cresswell) that if you can find any good uncracked head, Peter (Burgess) should be able to make it into a good-un for you😊.
Re: Cracked Head
A few years ago I was looking for a replacement cylinder head and a mate let me rummage through the ones he had. One was a 12H 2709. I took it to Slark Racing Engineering (then in Amesbury) and Brian Slark said he'd work on it over the winter. After a while he phoned me to tell me that one of the inlet valve seats was damaged, likely by ingesting something but he could get round it by fitting MGC inlet valves. Brian used to be the ace cylinder head man at Downton Engineering and he told me this was a "Downton Dodge." It goes really well and as Downton cylinder heads were renowned for flexibility the engine pulls well from low revs bearing in mind the 1.75 inch inlet valves and the HS6 SU's which are genuine British Leyland Special Tuning which I bought in 1981 with the matching inlet manifold.
Unfortunately I fitted the head then realised I hadn't photographed the combustion chambers.
The head it replaced was a "back door Downton" according to Brian when he converted it to unleaded last century as it had been welded but was a genuine Downton. I swapped it for the 12H 2709 head. The old head developed a crack but my mate was happy to swap. At the time he didn't know about the damage to the 12H 2709.
Hazza1190
Forename: Harry
Surname: Bukin
Re: Cracked Head
Post by Hazza1190 »
Hi Guys,
Thanks for the replies! After a lot of arguing with myself i have decided that i want to embark on a V8 conversion as its what i have always wanted. The current 1800 is toast (block is utterly worn and the head, well, you know about that!) so would need over a grand putting into it to get it where id want.
I understand that the later Rubber Bumper cars are easier to convert but I am going to convert my current project (1973 B GT). Any of you guys done a V8 swap, specifically on a chrome bumper? Im obviously going to go for a rover V8 (either the 3.5 or 3.9 im not too bothered). Any resources that you guys may have on this would be of great help!
Harry.
Forename: George
Surname: Wilder
Re: Cracked Head
Post by George Wilder »
Harry
Search the V8 site https://www.v8register.net/ lots of info if you search - complete projects documented
George
ChargedAutoGT
Forename: Graham
Surname: Moore
Re: Cracked Head
Join MGEXP and check out engine swaps. Hundreds of them and lots of Rover V8's
G
