GT V8 - unleaded
Posted: Sat Mar 04, 2023 4:00 pm
by 1340fxd
Newly bought 1976 MGB GT V8 - just found a bottle of Wurth lead substitute! Now I never gave it any thought but is a 1976 V8 likely to be designed to run on leaded petrol? If so, will using lead substitute do or will I have to get the heads updated?
Re: GT V8 - unleaded
Posted: Sat Mar 04, 2023 5:44 pm
by Bumpa
Because the Rover V8 engine is all aluminium, including the cylinder heads, it already has steel valve seats inserted. If it didn't the valves would quickly batter their way through the aluminium. So, no you don't need a lead substitute, and what's more you don't need a high octane petrol. After all, what you have is a low tune basic Land Rover engine, designed to be used in the far flung corners of the world where you take whatever fuel is available. I ran my V8 for years on standard supermarket petrol without an issue. I am putting the super grade in now to get away from 10% ethanol in ordinary petrol. The cost hurts but hopefully it might preserve my fuel system.
Posted: Mon Mar 06, 2023 1:56 pm
by Not_Anumber
unlike the 1.8 B series there was never an issue with unleaded fuel on the V8. Being a rebadged Buick engine it was designed from the start to run on unleaded fuel many years before unleaded was available in the UK
Posted: Fri Mar 10, 2023 11:01 pm
by 1340fxd
Thanks guys - I'll throw the Wurth lead substitute in the bin. However will use Shell E5 RON 99 fuel just to keep the ethanol down. What a waste as the engine is very low compression so does not need the high octane rating I'm paying for. Only solution is to fit a tuned higher compression head!
![Laughing :lol:](./images/smilies/icon_lol.gif)
Posted: Wed Apr 05, 2023 10:15 am
by Statler
And don't forget you'll need two....
I run the GT on Super and even though it has hardened valve seats, I still use Millers fuel additive in it.
Posted: Wed Apr 05, 2023 8:50 pm
I have to run my 1975 Land Rover on super unleaded even though the engine is 8:1 compression and it's 17p a litre dearer than E10 rubbish. It has a 1985 2.5 litre engine which was fitted with an unleaded head at the factory from new. No need for expensive unnecessary additives. My MGB has an unleaded head as well but I think it's cracked as overheating occurs.
The Land Rover runs very well on super unleaded. I have to use super unleaded in my chainsaw, strimmer and hedge trimmer too.
