mgb parts
- Forename: john
- Surname: bonner
mgb parts
hi can anyone help please. i am looking to get a Radiator Fan Switch Wiring Harness Plug for Thermostatic Switch MGB 1977-80. can not find one any where.
Re: mgb parts
I presume you mean the Otter switch in the radiator top tank. The plug for it is part of the wiring harness . If that's broken you'll have to make s connector to bridge the switch contacts.
The Otter switch itself is URP 1126 and its sealing bush is URP 10
Re: mgb parts
You could always try Welsh MG who break cars & can supply bits from old looms. (They supplied me with the plug that joins the loom to the brake fluid warning switch below the dual master cylinder of the late RB cars - mine had corroded & they aren't available new as a separate item).
Re: mgb parts
Andy Jennings is another possible source. He's in Curdridge in Hampshire.
Re: mgb parts
MGB Hive also break cars and will supply odd bits they've salvaged.
