Overheating
Re: Overheating
No Charles. I can push it and I never leave the handbrake on in the garage. It's always in neutral with a chock in front of the offside rear wheel.
- Surname: Wheatley
Re: Overheating
I did a 50 mile round trip yesterday, and the temperature was significantly hotter than normal on N instead of half way between. It was a hot day, so that obviously didn't help.
My car goes well over N if I get into slow traffic, but never gets to the red. I run retarded on account of the unleaded.
I wonder if these cars have been marginal on the cooling since new.
Re: Overheating
Hi Dave,
In standard form the 4 cylinder engine cars are very tolerant of operating in warm climate conditions. Certainly the temp gauge rises when the car is held up in stop start traffic. I holidayed fro many a year in the 80's with the MGB (that i still have) in the south of France with no issues. I am aware that there are differences in where individual car's gauges read for any given temperature of the engine - i guess it's knowing what is normal for one's own car. My fan (touch wood) always kicks in before the gauge gets to red & about 2/3 across the range of the gauge.
More problematic is the life of the water pumps & the heater valve - but i believe the former is possibly due to the lack of regular use of our cars.
I'm sorry to hear that Vic hasn't found an easy solution to his overheating issue.
Re: Overheating
I hope to make a start in the next week or so. Hopefully I'll have the Land Rover back soon, now with heated windscreens and 2 speed wipers, plus a brand new bulkhead which was made in Doncaster the last week in May this year.
Some years ago the MG overheated and the cause was a water pump which had sheared the drive to the impeller. That's not the case this time unfortunately.
- Surname: Wheatley
Re: Overheating
Charles, ta for that.
Good luck Vic.
Let us know how you get on.
Good luck Vic.
Re: Overheating
Vic, regarding pressure tests/compression tests.
Just to be clear in what I was saying in an earlier post:
The compression test I was recommending was a cylinder compression test to check for a leaky valve.
The coolant test was for exhaust gases in the coolant to check for leaking head gaskets or possibly a crack in the head.
https://www.eurocarparts.com/p/euro-car ... gJ5LvD_BwE
Just in case of any misunderstandings![😊](//twemoji.maxcdn.com/2/svg/1f60a.svg)
Re: Overheating
A compression test was done and all OK. I'd like to have a coolant pressure test done but with the position of the expansion tank tight against the offside inner wing I can't see how it could be done as there's no room to get the tester on to the expansion tank.
It was 6 years ago I fitted the cylinder head and I used a torque wrench that was long in the tooth to torque down the nuts. I now wondering if the torque wrench was accurate. I don't suppose the car has done more than 7/800 miles since.
I think I'll treat myself to a new torque wrench.
Re: Overheating
Vic,
I trust all your coolant hoses are in good condition?
I have read elsewhere that if the hose walls are weak,under increased pressure at higher rpms the hose can partially collapse & restrict coolant flow & hence cause over heating.
I may have missed it but when did you last change the coolant if a standard anti freeze & water mix.
Your annual mileage is very low,so has corrosion created poor flow?
Just trying to find an easy & cheaper fix!
Re: Overheating
Thanks Charles. The Kevlar hoses are in good condition and there's no problem with the flow as it doesn't overheat when I run it stationary.
I'm getting the Land Rover back this morning and then I'll make a start soon on MG head removal.
At least it's an easy job. There's someone further down my road who's got to remove the head on a 52 plate BMW and he's got all manner of electronic junk to deal with. In addition he thinks it needs new rings. The simplicity of MG ownership.
Re: Overheating
Hi Vic, given all the other things that you have checked so far, and the few miles your car has been doing is it a clogged up radiator that is causing the problem. The standard radiator is a bit marginal when the engine has been modified a bit so a new standard one might be the answer. Or try back flushing the one you have and see what comes out!
If the head is cracked and it is cracked into the water jacket, then you can usually smell combustion fumes in the coolant. It will also blow the coolant out of the system. This might only happen at higher rpm. It can crack elsewhere but in my experience that has little effect on the running and is only found when the head has been taken off for a top end overhaul.
