Exhaust manifold nuts
David Witham
Forename: David
Surname: Witham
Post by David Witham »
When taking the engine and gearbox out to change the speedo drive worm gear in the back of the overdrive, I found there was an exhaust manifold gasket leak. My car has a Tourist Trophy tubular stainless manifold and system.
I am careful not to tighten brass nuts too tight in case they strip and this may a have been a factor. The manifold nuts I bought new to fit the manifold last year were thicker than normal nuts but not as thick as I remember the brass manifold nuts being in he past. The number of threads in the nut will presumably have some bearing on the torque it will take before stripping.
Does anyone know of a good source of manifold nuts?
Re: Exhaust manifold nuts
Hi David,
I have the original manifold which i removed 3 years ago to access the tappet covers. I obtained new brass nuts ref GHF261 from MGOC Spares & have had no problems with them.
David Witham
Forename: David
Surname: Witham
Since my post yesterday I have found that Spalding Fasteners have just what I was looking for. Theirs are 3/4 inch thick.
Hi David,
I have used Spalding Fasteners quite a bit for replacement of a lot of nuts & bolts with Stainless Steel versions for the MGB where stress is not an issue.
I've got MGOC brass barrel nuts on the manifold to head on my BGT. They will fit the downpipe studs on the standard cast iron manifold and interestingly the manifold to downpipe studs on my 1975 Series 3 Land Rover. Being longer than the studs, they stop corrosion on the studs and I can remove the carburettors on the inlet manifold on my BGT too.
ChargedAutoGT
Forename: Graham
Surname: Moore
Post by ChargedAutoGT »
I too have the long MGOC brass ones. last time I put the manifold on I stripped two of them but they have been on and off a few times whilst designing supercharger. But it's a lesson learned - in future i would only reuse maybe a couple of times. When one went there was one heck of a ping that I thought the manifold flange had cracked, so was very happy when it was the nut that had failed.
Slightly off topic David, but is your Tourist Trophy exhaust the one sold by Moss with flanged joints? https://www.moss-europe.co.uk/exhaust-s ... 9-075.html
If it is, how do you like it? Is it noisy? The flanged joints must be a good idea in preventing leaks.
David Witham
Forename: David
Surname: Witham
It is the one sold by Moss but I have the one that comes with a matching tubular manifold.
I like the flange joints. They make taking it apart for other jobs very easy.
The system feels very strong and the modern style mountings are probably an improvement.
It was a bit noisier than I expected. However, when I removed it to take the engine and gearbox out I found I had a leak at one of the joints under the car and around 2 of the exhaust ports at the manifold to head gasket. Since putting it back together I have not had a chance to try it out properly.
Thanks David. I'm rebuilding a '71 roadster at the moment (when the weather is not quite so bally cold!). One of those exhausts may go on my shopping list.
